Use the following procedure to clear Internet Protocol Security (IPSec) system statistics counters and view IPSec statistics on an interface. The device only clears system statistics counters on system reboot.
  1. To enter User EXEC mode, log on to the switch.
  2. View IPSec statistics for the system:
    show ipsec statistics system
  3. View IPSec statistics for an Ethernet interface:
    show ipsec statistics gigabitethernet {sub-port]][,...][slot/all][all]}
  4. View IPSec statistics for a VLAN interface:
    show ipsec statistics vlan <1–4059>
  5. View statistics for IPSec on the loopback interface:
    show ipsec statistics loopback <1–256>
  6. Clear IPSec system statistics counters:
    clear ipsec stats all
View IPSec statistics. Output is partial due to length.
Switch:1>show ipsec statistics system
                            IPSEC Global Statistics
InSuccesses          = 0
InSPViolations       = 0
InNotEnoughMemories  = 0
InAHESPReplays       = 0
InAHFailures         = 0
InESPFailures        = 0
OutSuccesses         = 0
OutSPViolations      = 0
OutNotEnoughMemories = 0
generalError         = 0
InAHSuccesses        = 0
InESPSuccesses       = 0
OutAHSuccesses       = 0
OutESPSuccesses      = 0
OutKBytes            = 0
OutBytes             = 0
InKBytes             = 0
InBytes              = 0
--More-- (q = quit)
Switch:1>show ipsec statistics gigabitethernet 1/13
                              Ipsec  Port  Stats
Ifindex              = 204
InSuccesses          = 0
InSPViolations       = 0
InAHESPReplays       = 0
InAHFailures         = 0
InESPFailures        = 0
OutSuccesses         = 0
OutSPViolations      = 0
generalError         = 0
Switch:1>show ipsec statistics vlan 1
                               Ipsec  Vlan  Stats
Ifindex              = 2049
InSuccesses          = 0
InSPViolations       = 0
InAHESPReplays       = 0
InAHFailures         = 0
InESPFailures        = 0
OutSuccesses         = 0
OutSPViolations      = 0
generalError         = 0
View IPSec statistics for a loopback interface:
Switch:1>show ipsec statistics loopback 1
                             Ipsec  LoopBack  Stats
Ifindex              = 1344
InSuccesses          = 0
InSPViolations       = 0
InAHESPReplays       = 0
InESPReplays         = 0
InAHFailures         = 0
InESPFailures        = 0
OutSuccesses         = 0
OutSPViolations      = 0
generalError         = 0
Use the data in the following table to use the show ipsec statistics command.
Variable
Value
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
loopback <1–256>
Identifies the loopback interface.
system
Shows statistics for the entire system.
vlan <1-4059>
Specifies the VLAN.
